The loco in the next post. All I know about its description is it was used by a logging company.
It looks like the boss's whole household is on the train.
Anyone recognise this loco?
- Maltelec
- Master of the Forum
- Maltelec
Re: Anyone recognise this loco?
- Stirring the Pot
- Boat Name: Steam Queen
I would like to say it's a Shay but a three cylinder ,two truck Shay is bigger than that. The boiler is sitting very low,there is no frame-the boiler is mounted directly to the front truck. Maybe someone built it out of a wreck.I could not find any Shay photos that resemble this and Shay had the patent on this set-up.When the patent ran out Willamette produced similar engines but much bigger than this so it's gotta be a Shay! Den
- Akitene
Good evening,farmerden wrote:I would like to say it's a Shay but a three cylinder ,two truck Shay is bigger than that. The boiler is sitting very low,there is no frame-the boiler is mounted directly to the front truck. Maybe someone built it out of a wreck.I could not find any Shay photos that resemble this and Shay had the patent on this set-up.When the patent ran out Willamette produced similar engines but much bigger than this so it's gotta be a Shay! Den
I'm pretty sure it's not a Shay, because of the position of the cylinders steamchests facing outward. But this loco is clearly built alongside the design of a 2 trucks Shay. The boiler is also very special. This could be a very early Shay, a kind of "proof of concept" for the side-transmission?
Regards.
- Akitene
Wouldn't it be for the curious boiler, this could be a Willamette (a late clone of Shay with outward facing valve chests):
http://en.wikipedia.org/wiki/Willamette_locomotive
- Maltelec
Den sent me an Email from a friend of his:
Hello Dennis:
That appears to be Ephriam Shay's Hemlock Central locomotive. The Engineer in the picture has a strong resemblance to Ephriam Shay himself. Here is a link. Scroll down and you will find the same loco. I am no Shay expert, but consider them the best darned locomotives ever built! Can you send a link to your forum? Let me know if you think it is the same loco.
Thanks.
Jack Hudson
http://www.shaylocomotives.com/shaypage ... imShay.htm
Hello Dennis:
Thanks.
Jack Hudson
- Stirring the Pot
Jack says he's no expert on Shays but how does he explain making this from scratch??
[/img]
Interesting engine. My guess is it's a Shay, the components look similar just rearranged. I have a Mich-Cal 2 cylinder Shay from Accucraft. I was at a friends house and seen it in a showcase, and had to have it. He sold it to me.
Anyways, it would be fun to know that pic was taken in Northern Michigan, there were a lot of Shays up there, Shay being from Northern Michigan.
