"Rushforth"
Moderator: csonics
csonics
Anne from Little Britan
"Rushforth"
Post by csonics »
Posted on behalf of mcandrew1894:
mcandrew1894
Full Ahead
Posted: Thu Oct 11, 2007 5:57 pm Post subject: "Rushforth"
Hi
She's based on "Panatela" but 5' wide x 25'
She just touched the water for the first time...sans boiler
http://s164.photobucket.com/albums/u27/ ... 010214.jpg
http://s164.photobucket.com/albums/u27/ ... 010031.jpg
http://s164.photobucket.com/albums/u27/ ... =DYNO2.jpg
http://s164.photobucket.com/albums/u27/ ... nt=P-1.jpg
http://s164.photobucket.com/albums/u27/ ... 010216.jpg
Boiler is almost done...then it's time to put it all together!
Regards,
Back to top
Edward
Posted: Tue Oct 23, 2007 11:11 am Post subject:
It's a nice looking engine. could you give us some details?
Back to top
mcandrew1894
Full Ahead
Posted: Fri Oct 26, 2007 5:35 pm Post subject: engine
Thank you for the kind comments.
She is obviously a compound. 1.5 x 3.0 x 2.5
Inside admission on HP and outside on the LP
stephenson valve gear with box links
Piston valves
2 HP @ 600 rpm w / 160 psi She"ll go up to 1800 rpm if you let her.
I designed and built her myself with only the cylinder blocks and the standards as castings ( my patterns) The rest of the engine is bar stock.
She has a "Seabury" style receiver plumbing that is through bolted and sealed on a face seal. This allows for thermal expansion.
The engine is lagged in brass.
Back to top
Edward
Posted: Sat Oct 27, 2007 9:29 am Post subject:
Thanks for the dimensions. What results did you get when you put it on the brake?
Edward
Back to top
mcandrew1894
Full Ahead
Posted: Sun Oct 28, 2007 7:53 am Post subject: Brake Results
The steam was quite wet as it was at the end of a 20 foot long steam table.
At 80 psig ( all the boiler would do) and 600 rpm I got 0.75 BHP.
My boiler is capable of 150...160 to lift the safety, and If I am dryer than the test....which I should be, and using a condensor, which wasn't used in the test, I should come close to 2 BHP @600 rpm
She is capable of higher speed, but 600 was the design speed.
Back to top
mcandrew1894
Full Ahead
Posted: Wed May 06, 2009 7:59 pm Post subject:
First Day out! Last fall on Lake Manomonac in New Hampshire
Much left to do but it's coming along now.
Back to top
Full Ahead
Posted: Thu May 07, 2009 7:04 pm Post subject:
beautiful boat.
Those panetela style hulls look great and have great performance
_________________
Wesley Harcourt
-'64 Buick Riviera
-'65 Buick Special WAGON
Back to top
mcandrew1894
Full Ahead
Posted: Thu May 07, 2009 7:43 pm Post subject:
Thanks for your kind words!
"Those panetela style hulls look great and have great performance"
Yes they do!
Very stable too...initial and ultimate
6.3 mph @ 100 psi without condensing.......can't wait to try the condenser and the new economizer.... 150 sustained should be no problem....160 with the condensor
Back to top
mcandrew1894
Full Ahead
Posted: Tue Jun 02, 2009 9:57 pm Post subject: First Year Plumbing is done!
We'll see what we change after this......
Back to top
Full Ahead
Posted: Wed Jun 03, 2009 7:02 pm Post subject:
that's a beautiful setup
_________________
Wesley Harcourt
-'64 Buick Riviera
Back to top
mcandrew1894
Full Ahead
Posted: Wed Jun 03, 2009 10:23 pm Post subject:
Thanks Wesley!.....We'll try the metering valve and see....
Back to top
mcandrew1894
Full Ahead
Posted: Sun Jun 21, 2009 6:46 pm Post subject:
Went for the Coast Guard safety inspection and got the sticker!
The old salt said" In 35 years of doing this I have never had to check off
"other" in the fuel column"....
Now if it will stop raining .........
Back to top
Full Ahead
Posted: Sun Jun 21, 2009 10:44 pm Post subject:
LOL that's great!
We were listening to the CB radio on our boat one time when we hear a call to the coast guard (yep the coasties have a "R&R" station on Tahoe) about a boat on fire..
_________________
Wesley Harcourt
-'64 Buick Riviera
