How does this engine work?
- Stirring the Pot
- Boat Name: Steam Queen
Re: How does this engine work?
I have to agree with Fred "We all like to see things go up and down" If this was a superior design [a better mousetrap] then the world would have beat a path to this fella's door! Den
- Maltelec
- Master of the Forum
I think Ron has a good point. You've removed the wear from the large crosshead guide and stuck it all on a much smaller crosshead.
I think beyond even that there is a serious operational safety issue with an engine design like this. I suspect that an engine like this could easily be nicknamed "The Finger Crusher". Can you imagine if you or a passenger accidentally grabs either one of the supports? YEEEOUCH!Maltelec wrote:I think Ron has a good point. You've removed the wear from the large crosshead guide and stuck it all on a much smaller crosshead.
Not that the insides of moving steam engines are ever places you want to stick your fingers, but with a more conventional design you are FAR less likely to lose an appendage with an errant-placed hand than with this design.
Although I'd imagine that it would have a useful life as an automatic walnut-cracker!
- Stirring the Pot
don't be mislead into thinking conventional steam engines aren't dangerous .I can't seem to get a season in without crushing the tip of my oil can! And it happens so fast!! But I never thought to use one as a nutcracker!!
Den
In tooling they are called "pinch points" whereas at least 1" of clearance is maintained on all shearing motion, this design would never make it past safety.Wearyman wrote:I think beyond even that there is a serious operational safety issue with an engine design like this. I suspect that an engine like this could easily be nicknamed "The Finger Crusher". Can you imagine if you or a passenger accidentally grabs either one of the supports? YEEEOUCH!Maltelec wrote:I think Ron has a good point. You've removed the wear from the large crosshead guide and stuck it all on a much smaller crosshead.![]()
If something fell down and got wedged at high rpm, the inertia/force would probably ruin the engine, bend the frame.
mcandrew1894
I think that was Dave's.....its a relatively big engine....maybe 4x4 or so.
I believe it is cast and was made by Lombard, of the Lombard Logger fame.
I believe you're correct. His daughter is selling his stuff. And yes it's made by the same Lombard as the steam log hauler.mcandrew1894 wrote:I think that was Dave's.....its a relatively big engine....maybe 4x4 or so.
mcandrew1894
Thought it looked familiar....saw it at George's one year many moons ago.....it was facinating to watch.
Richard Orr
I don't know...put some ball bearings around the wrist pin and this design may reduce friction.
Working on an engine design for a 1790 steamboat (John Fitch, Philadelphia PA, USA), I came across a James Watt Patent for his straight line mechanisms. The difficulty of getting a steam engine piston rod to move in a straight line was a serious challenge in the industry at that time.
One of the drawings in the Watt patent shows a "crosshead guide" that is virtually identical to the one on this engine.
- Watt1784patent.jpg (90.61 KiB) Viewed 14147 times
