- Stirring the Pot
- Boat Name: Steam Queen
What a beautiful sound! And moving at a pretty good clip for 46 RPM! Den
mcandrew1894
It would appear she's moving with some authority Fred! Looking good!
- kno3
Great sound, love it!
Congratulations Fred!
Runs very nice, she marches right along!
- Aheadslow
Wow, Its amazing what happens when you wind up in the hospital for a couple of months.
Had a little accident on the last job. Anyway absolutely incredible job on the boat there Fred . I wish I had your organizational skills. The speed with which you accomplished this build is very impressive, it looks like youve got a winner there. Congratulations on a job well done. I cant wait to see her after final fitout. should be a real beauty.
A picture that appeared in the steamboating magazine "The Smokestack" at the end of 2010, (although there was no smokestack on the boat at the time).
Much thanks to all of you who provided guidance and suggestions during the building process. I remember buying the steel wheels (farm implement wheels), which form the basis of of the paddlewheels, in the late 1970s, at a “yard sale” for $10. At the time I knew exactly what I would use these wheels for, yet it took more than 30 years before the sidewheeler was actually steaming on the water.
I think the real spark that got me to proceed with the project came from a seafaring man named Sterling Hayden, his words that follow hold value for me, and possibly many others:
“The years thunder by, the dreams of youth grow dim where they lie, caked in dust on the shelves of patience. Before we know it, the tomb is sealed.”
- Lookout-Wife Katharine, with our two Tibetan Terriers in the bow, Son Jeanpaul at the stern, and Fred tending the machinery, First Outing
- 10 Oct 2010 TrialsSSS.jpg (193.49 KiB) Viewed 19757 times
Chris W
- Boat Name: Medea
She's a beauty! I wish I could remember where I read the term "perambulating waterfall" used as a description of a sidewheel steamer.
bkueber
Oh Wow
What a fabulous sound! DO you have more info on the engine you built for her. You gotta love walking beam engines!
Regards,
Bret
Bret
There is info on this engine under the "Technical - Engines and Boilers" Section of this website, under "American Walking Beam Engine". I really like the slow speed of the engine, getting to see everything rocking and rolling, making the boat move forward. I still plan a condenser, which will virtually silence the exhaust note, but I think I will usually run with the exhaust to atmosphere, I like the music of the machine. It uses Marshall-Bremme Valve Gear.
- Walking Beam Engine, with Wet Vacuum Pump and Boiler Feedwater Pump, 90 RPM 1 HP Rated
- WBE2007S.jpg (206.26 KiB) Viewed 19757 times
Putting small deck pieces around the hull, about 5 inches wide all around, with a small coaming.
Also epoxied in the vertical stem piece, made of 3/4 inch extra heavy steel pipe. I was going to use brass pipe, but they wanted $175 USD for a 10 foot long piece! The forward eye for trailer winch attachment was welded to the pipe, and through bolted to a large reinforced piece of wood epoxied into the bow. I think the entire boat could be suspended from this eye. Lower down, two steel flat bars secure the stem to the bow, so I can ram something without the stem coming loose.
- 1/2 inch thick nine layer plywood decking with small coaming 1-1/2 x 1/2
- FwdDeck-Coaming.jpg (88.87 KiB) Viewed 20327 times
- Stem Piece in Place, with Winch Eye
- Bow-Stem.jpg (84.32 KiB) Viewed 20327 times
- Stem Flat Bars, Welded
- StemWelds.jpg (73.97 KiB) Viewed 20327 times
