Freezerrr12
- Boat Name: Anastasia
Greetings to the forum participants! I'm on the forum again after the winning of Covid-19. Working under the project. Kindly find the pictures attached.
You are alive!! So happy.
Freezerrr12
Also wold like to thanks Mike for being happy with me.
- IMG_5931.JPG (118.85 KiB) Viewed 316633 times
- IMG_5933.JPG (140.71 KiB) Viewed 316633 times
Freezerrr12
Continuation. I managed to finish the steam flange, besides i have already finished valve box mechanism.
- IMG_5991.JPG (125.97 KiB) Viewed 316628 times
- IMG_5989.JPG (115.7 KiB) Viewed 316628 times
Freezerrr12
And this is the work under the cylinder cover.
- IMG_6005.JPG (124.15 KiB) Viewed 316627 times
- IMG_6004.JPG (149.71 KiB) Viewed 316627 times
- IMG_5999.JPG (169.93 KiB) Viewed 316627 times
Glad you're both alive!
Looking good. Getting closer and closer...
Yes indeed I will second that. Nice to see that you are still working on the engine. I do like the 'bits' as everything is large and looks just like I feel steam engines should look. I appreciate the skill that goes into making tiny engines but the big ones have the gretest appeal for me. Looking forward to the next instalment.
Freezerrr12
I welcome all forum participants, especially those who give me advice and recommendations for the further promotion of my project. Despite the unfavorable circumstances, I continued the external processing of the cylinders. This work is visible in the photo. The cylinder has become 2,5 kg lighter.
Freezerrr12:
So glad to hear more from you. Good progress.
Stay safe and keep sharing your progress with us.
Freezerrr12
A general approximate view of the steam engine is also on the photo. The bronze fittings (elbow pipes) are 1 1/2 inches in diameter. The copper pipe is the same size. Advise to what extent it is necessary to increase the diameter of the copper pipe between the cylinders? Is a receiver between the cylinders really necessary?
The length of the copper pipe is 0.5 meters, the diameter is 1 1/2 inches. The approximate volume of steel pipes with bronze elbows is about 1,000 cm3. ( 1 liter)
This volume is equal to the volume of the high pressure cylinder.
