Mjolnir wrote:Hi Mal, Gearing could be applied either way...if you had a long stroke low speed engine and a hull with a small clearance for the prop. you could gear the speed up to allow a smaller propellor. <snip>
The boiler I am building is a three drum Yarrow style of thing, an 8 inch steam drum and two 5 inch mud drums. Five inches is too small for easy expansion of the tubes, they should have been at least six, <snip>
Incidently I did make one major modification to the Leak, I fitted a piston valve to the LP as well as the HP. <snip>
Interesting John - I had always thought (not being nautically knowlagable) that running props very fast was not efficient (cavitation and all that), so I had assumed that there would be an "optimum speed"...
On the "expanding the tubes" I was also thinking that expanding the tubes in the SBA's design with 4 inch mud drums almost 30 inches long might be something of a "challange" ! - I am assuming you can get "round the corner, long-handled expandery thingies"....
Twin piston valves.... I think I will stick with the balanced slide valve, as that should avoid the loading problem, but I must confess that as I am still just tooking at the drawings in the Cambden "guide" (as opposed to the real drawings) it is hard to quite see how "balanced" it is!
