My 24' Launch
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
A warmer day Saturday, so another coat of epoxy base ...
Epoxy Base Coat (2).JPG (92.18 KiB) Viewed 37839 times
Re: My 24' Launch
Post by 87gn@tahoe »
That's a good looking engine. What is the make and what are the dimensions?
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Wesley:
Mills-Beaumaris, 2.5 x 4.875 x 4.0
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Bottom paint is on. I'm still fooling with the topsides prior to painting.
Bottom Paint (Resize).jpg (118.55 KiB) Viewed 37792 times
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
So here's a funny thing: As I continue to dismantle the engine while things are drying on the hull, I "discover" that the front main bearing is a roller bearing and the main rear are tapered Timkens in indirect opposition. I was a little crest-fallen ...
There's a story here. I've spent part of my adult life in attempting to perfect an expertise in the obsolete art of the care and feeding of plain bearings. There's a certain joy in taking a scraper to a problematic bearing that tends to run hot and turning it into a contented member of the team. Most of this has been in rail preservation, so when it came time to shovel over the carefully hoarded dollars for my very own marine compound, part of the dream was having plain main bearings. Bearings I could caress into cooperation. Well, there's plenty else to caress into cooperation on this engine, and some of you are probably forming the opinion that I'm a little daft, but so what? I'll leave the bearings be and won't convert them or their housings to plain.
Re: My 24' Launch
Is it that the rear bearing, being a tapered roller bearing, has the duty of thrust bearing for the propeller forward thrust? If so, then what would take the thrust in reverse? I am assuming the tapered roller bearing is similar to those found in typical automotive practice, but two opposing ones are provided on an automotive axel to take thrust in two directions.
Tapered roller bearings are well evolved machines, and take thrust far beyond anything envisioned for a small launch thrust bearing. I like sleeve bearings, they will outlast any type of roller/ball bearings if properly designed, and maintained, but the rolling element bearings can take so much more load than sleeve bearings. A typical automotive tapered roller bearing should also last indefinately in the service of main crank/propeller thrust bearing for a steam launch.
tapered roller bearing.jpg (5.89 KiB) Viewed 37785 times
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Fred:
There are two in indirect opposition, like a wheel axle. I'll still have a separate thrust bearing on the prop shaft, to keep the wear and tear off the engine.
Yes, they should be very durable and will last indefinitely in this app.
Re: My 24' Launch
Steve,
Your hull is looking great!
Really like the lines.
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Ron, thanks for the encouragement. Little by little ...
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Found a build date the other night while scraping red lead out of the forward main bearing location on the bed plate. So now some questions are answered and there's enough information for an engraved engine badge plate:
Beaumaris Instrument Co. Ltd.
Engine No. 5
February 1973
I would be grateful for any other history anyone might have on this engine.
