My 24' Launch
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Momentous Saturday; we flipped the hull. No pictures since hull-flipping is right up there with sausage-making and making whoopee - better not to be seen. An old box spring with mattress provided the needed port-side cushioning. I was pleased that the topside paint did not so much as scuff.
She's on her keelblocks now with the molds out. I have to support the rest of the hull and then interior work will begin in earnest.
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Finishing out the interior ...
IM009464 resize.JPG (153.78 KiB) Viewed 23973 times
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Another perspective ...
IM009465 resize.JPG (192.75 KiB) Viewed 23973 times
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Wet epoxy in the box keel area.
IM009467 resize.JPG (184.93 KiB) Viewed 23973 times
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Brother Anderson continues to labor at the engine's air and water pump. Here are the pumps with glands fitted:
2012-08-26 Pumps w Glands Resize.jpg (125.44 KiB) Viewed 23945 times
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Here's the air pump head with gland and guide fitted:
2012-08-26 Air Pump Head Resize.jpg (92.71 KiB) Viewed 23945 times
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
One can never have enough tools - we had this air pump head wrench made at the local laser cutter's:
2012-08-26 Air Pump Head Wrench Resize.jpg (121.05 KiB) Viewed 23945 times
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Here's the air pump sleeve in place:
2012-08-26 Air Pump Sleeved Resized.jpg (99.31 KiB) Viewed 23944 times
Rainer
Boat Name: Emma and Molly
Re: Sleeves
Post by Rainer »
I like this sleeves.
Do you plan to run rings in the pump? What material?
S. Weaver
Boat Name: SL Iona
Re: My 24' Launch
Post by S. Weaver »
Rainer:
We'll machine the piston with the traditional water grooves to provide the seal.
