Howdy all,
I have a prop question. I ran a 18x18 last year on my 3x4 simple pushing a 23 foot hull a d things seemed to work well. There is a new 18x23 for sale locally for short money. Would it provide me any benefit ?
Jon
Propeller selection
Re: Propeller selection
Hi Jon,
I went up on propeller pitch 20X20 3blade to 21X23 4 blade. My boat runs much better now. Slower RPM, lower steam consumption and much faster.
For "short money" you should buy it. A prop with long pitch is wanted by many steamboaters, so if you do not find it right for your boat, you can sell it at Lee's Mills and save a bundle of money for a fellow steamboater who will not have to pay $500 for a new prop.
JonRiley56
Thanks Guys !
I will see if I can grab it.
jon
jon
My boat is a 3 x 4 simple, 24' and was running an 18 x 20. It was O.K. but I found an 18 x 24. It reaches about the same top speed or maybe a trifle faster but the 'sweet spot' speed for cruising moved up a fair amount. I'd go for it.
My 18 x 20 is available for testing and purchase/trade. 1.25" shaft R.H.
JonRiley56
Thanks Mike
A guy at work was thinkingI would have trouble slowing down to dock etc.
Should.I be concerned ?
Jon
Jon
No. You should be so lucky.
m
m
Yep, he may be right. The new faster at slower RPM for us has taken a bit of getting used to at docking. Also, under 20 PSI moving forward, I can't go in to reverse, the steep pitch overpowers the engine at that pressure.
That's steam though, most improvements are a compromise. And what works for one, may not work for another.
