Umm Bart...
You'll need sufficient draft to cover the prop at rest, and provide a skeg for protection.. The draft in front will be much less, otherwise our displacement will go through the roof. 7000 lbs is only about 110 cubic feet of water; since we're talking 30' x 8' parts of the boat will just be touching the water. This is good; we'll have lots of reserve buoyancy for taking an extra 10 people around the harbor at a steamboat meet.
Dude that 7000# figure was for both; I will make sure that I leave the trailer at the boat launch.
The specs say she displaces 4410#, now I am not sure that is the figure for the 30’ x 8’ variant of the build plans but is probably close. The draft is listed as 24” according to Paul at Selway Fisher I can swing a 20” prop without any problems.
There are some places with nothing but rocky beaches or with a scary approach; rowing in to see what your options are sure beats repairing things. I'll definitely carry a dingy when cruising; we'll build one to fit the roof of the cabin. Some beaches shoal very slowly and keep a boat with 3' draft 100 yards offshore at medium tide; the beach closest to our property on Lopez Island (Swift's Bay) is like that.
You know A small dinghy up on top the cabin is not something I had thought of. I will have to mull that on over.
I've run into invisible submerged pilings - fortunately slowly and head-on.... no damage. Getting stuck in the mud _is_ a real PITA... I've waded for many yards, pushing the boat through stinking anaerobic mud to get back into the (unmarked) channel with passengers aboard.
Getting stuck in the mud brings to mind a system my sailboat architect told me about that he had seen in South America on a riverboat. My interpretation of his description is as follows.
It consisted of a set of bronze eyelets mounted on the gunwale, two, port and starboard quarter and two, port and starboard bow. They used the eyelets to hold two poles about 2.5” by 10’ or so and had a fixed pulley on one end of each pole. A single sheave pulley with an eye was shackled to the bronze eyelet and a line was run from the pulley eye then up and over the end of each pole then down to and through the pulley. The end of the rope was then wrapped through a winch. When used the pole would push down through the bronze eye, which would lift the boat a bit and push backward at the same time. They were used to back off mud banks and such when they got stuck or after the boat was loaded and they needed a bit of a push off the shore.
I have never seen them in use but the reason he related the story to me is I had asked about parking my sailboat on a beach and letting the tide go out without it. I wanted to make sure she would sit on her keel with no problems and a similar pole arrangement was suggested to be used simply as braces.
I remember watching the original Mosquito racing for the launch ramp, pumps working. She'd spent a night sitting on the hard getting patched after stoving in her planking on a hidden submerged piling in the Snohomish River basin.
ACK!!! Now ya got me nervous... I wonder if they make a small forward seeking sonar system?
It would probably be more expensive than the whole boat huh?
Cheers,
