You said that a piston pump could be used? Today I am replacing the lower seals “again” in one of our barrel pumps (the monkeys did not clean out the 3M last night) and I had a thought.Some design comments on the Lamont... you'll need to insure turbulent flow (say Reynold numbers above 10000 or so) to realize the advantages of the pumped circulation. This means about 2 gpm in 1/2" pipe - not a lot, but it needs to happen so long as you have fire. I'd not consider solid fuel suitable for a Lamont boiler w/o redundant pumps & reliable pump power; I'd also consider multiple pumps required (or some other form of aux. power) if in open/dangerous (tides/currents/surf) waters. Remember that the pump only needs to produce a few psi pressure head - but the seals need to take full boiler temperature and pressure, which is what makes finding such pumps difficult. Also, the water you're trying to pump is about to flash into steam, so the design of the pump needs to require a very low NPSH.
From Wikipedia: "Careful design is required to pump high temperature liquids with a centrifugal pump when the liquid is near its boiling point." You can use a positive displacement pump, but gear pumps are probably out since any scale or such in the boiler water would soon trash the pump. A 2" bore, 1" stroke double acting opposed piston pump with lift checks and Viton or Teflon packing running about 100 rpm would do the trick - but it has to run all the time, even when the fire is just lit, so you'll need to use an electric motor.
This pump mechanism is double acting by way of a stepped piston. It has two sets of V rings, an intake ball valve in the foot and one inside the piston itself. The volume of the lower chamber is higher than that of the upper chamber so that when the pump cycles it moves material on each stroke. It has no packing gland since it is mounted inside the container so if it leaks a bit no big deal. The pump is driven by a 5 to 1 air motor that will move material the consistency of honey at little over 3 gallons a minute at 500 psi through a 1/2” hose.
What about mounting an entire pump unit “inside” the boiler loop. Say in a ported tank that could be isolated by valve next to its twin encase of pump failure. That way ya get a main pump and a backup or you could run both for a boost when needed. At 2” bore x 1” stroke the pump housings would not be overly large or heavy.
My thinking is to build something like this in bronze or? With Teflon rings and place it inside a suitable housing. Say 2,5” schedule 80 with flanges and valves appropriate for the job. The pump could be built lighter that way since it is only moving the water inside the pressure loop. The unit would be driven like those feed water pumps are with something slow and dependable.
Ya think an arrangement like that would move enough water to keep a steam engine of around 3+5 x 4 running? And yes I am terrible at math, I do better with things I can wrap my hands around.
Cheers,
