US Navy Type-K VALVE
Re: US Navy Type-K VALVE
marinesteam wrote:I've contacted Dave and now I am on the list to get my very own Navy K valve when he gets the next batch of castings. Yeah!!!!!
Yup, me too. :D
I love boat jewelry but a screw to hold a cotter pin? Maybe just a teeny bit over the top.
Like isn't the point of a bent pin that it prevents something from unscrewing?
This is envy talking.
Lopez Mike wrote:I love boat jewelry but a screw to hold a cotter pin? Maybe just a teeny bit over the top.
The screw is optional... Given my habit of dropping things into inaccessible areas, I'll use safety wire and keep a roll on the boat :).
marinesteam
Boat Name: Idris
Post by marinesteam »
Dave said that this detail was copied from a similar fixing on the clevis' from the York engine.
Yes it isn't the normal installation for a spit pin but I think the intent is to prevent the pin from rotating and wearing the hole in the clevis. This is a pretty elegant solution to that problem. The other end of the pivot pin is flush with the clevis and the screw & split pin also prevent the pivot pin from moving sideways out of the clevis. The part count is the same as with a split pin on both ends of the pivot pin and the part count is the same. I think this makes for a cleaner installation aesthetically.
Ken,
All very well and makes sense but it does violate the principle behind a cotter pin and/or safety wire which arrangements cannot vibrate loose. It wouldn't be allowed on and airplane or a race car or racing motorcycle.
I think it's elegant but on an aesthetic level only. If it were in a high vibration and control critical location, it wouldn't be a good idea.
I have this fun cartoon idea where the cotter pin has it's screw which has it's own cotter pin which has it's screw . . . . . . .
Surely better for the clevis to rotate, and even out the wear. I've seen many stepped ones in my day, where they didn't rotate. :?:
Ah, I think that if you wear out a clevis pin on your throttle that you are fiddling with your throttle toooo much! This ain't no sprint car.
This from a guy who is working on a Model A Ford's brake linkage where EVERY pin is toast.
Good engineering principals still apply Mike. :lol: :lol: :lol:
When I went through (mostly) Otter's 120 year old engine, I found the holes for the eccentric rod clevises well worn in the bronze Stephenson link casting... and the pins were completely shot. I bored the holes in the link out to 1/2" and turned and inserted Delrin bushings and made hardened pins to fit. The clevis ends completely hide the Delrin, and there's not even a hint of play or sound.
marinesteam
Boat Name: Idris
Mike,
I think that you're over thinking it. Not meant for safety, just another way to retain a pin in a clevis. :D
