My New Launch
Boat Name: grayling
Re: My New Launch
Post by steamboatjack »
Hi,
This is a fine looking engine and indeed the hole boat congratulations. I was particularly impressed by the duplex feed pump, a good size for a larger boat, can any members give more details regarding this item? Bore & stroke, supplier of drawings & castings etc.?
Re: My New Launch
Jack,
That is a Breisch pump once sold by Myersengines here in the states. They have been out of stock on these every time I have checked for the past few years. If you email him, he may run a set for you.
http://www.myersengines.com/engines/duplex_pump.htm
Water cylinder 1"
Steam Cylinder 1.25"
Stroke about 1.5"
SL Ethel
Boat Name: SL Ethel
Re: My New Launch
Post by SL Ethel »
I call or email the good folks at Myers every couple of years as well, in hopes of convincing them do do another run of castings. Are there many more people out there who are hoping for a set of those castings? Perhaps if we could put together a firm order for several sets, it might inspire them to cast another set.
Cheers,
Scott
Re: My New Launch
At one time Ronnie Baird was I think castings these sets for him and they even had them on their website with notation that they were part of the Clarence Myers collection. An email to Ronnie may produce a set.
I have a set of these castings I started to machine a long time ago, I hit two big air pockets in the pump casting and that ended my interest in it. I was already "not feeling it" with the fastener size with some as small as 2-48 if I remember correctly. I upsized all of them to 4-40 to make it serviceable dockside.
I opted instead for the Southworth 12" vertical single cylinder pump - I like it a lot better. It's vertical and doesn't take up too much room, about the right size for our boats, it keeps up with the water/steam hungry tug. I had some O-ring issues with it early on, which I re-did and used much better neoprene 75 durometer rings and it is very reliable now. I usually start it in the morning and let it run all day, even at the dock. The lubricator is the little scale locomotive type sold all over Ebay.
Jack, for a 40 footer, I doubt either of these pumps would be sufficient. I would look instead for a small Worthington, they show up on Ebay and engineads. They usually go for a reasonable price - not too many folks building 40 footers :D
Re: My New Launch
Absolutely amazing Kelly!
