My New Launch
Kelly Anderson
Boat Name: Vividus
My New Launch
Post by Kelly Anderson »
With bending and plumbing two cylinder drain lines last night, I am declaring my launch engine “finished”.
I purchased a trunion hung automobile engine of unknown make at Cabin Fever several years ago, which I believe was a prototype, and virtually unused. The extra “cylinder” is an intercepting valve, which converts the engine into a true double simple. Another unique feature it has are inside admission balanced slide valves, something I have never seen even in books. The HP cylinder is steam jacketed and originally didn’t even have cylinder drains. Both pistons are hollow. The HP crosshead was badly out of line with the piston rod, something that wouldn’t have lasted in use, another reason to suspect that it was a prototype that was abandoned prior to testing.
Bores are 2-5/8" & 4-15/16". Stroke is 3-1/2".
New parts include:
Sole plate
Crankshaft
Flywheel & shaft coupling
Columns
Intercepting valve & bushing
Reverse shaft, arms, and lever
Air & feed pumps and their 1/2 speed drive
Steam and exhaust flanges
Cylinder drains
Cylinder jacking of powder coated brass & copper
Oil boxes and lines
Mechanical lubricator.
It had been assembled a few weeks ago, until I took it down to parts for painting, the reassembly process inspires me to quote Richard McKenna:
“Holman led them in refitting each bearing as they rebuilt the engine, pointing the conn rods to meet each crank fair and central, and day after day the heaped engine parts went back to their appointed places. The empty archways filled up with piston rods and bulky crossheads and connecting rods. Between them, eccentric rods forked up to either end of the double bar links. Holman worked in a driving fury and he carried the others with him. All the heaped and rusting confusion moved back into place and order, with every nut snugged up and locked, and every part fitted easy and true to every other part.
Ping-wen moved in his coolies to clean and polish and paint and the engine stood bravely new…”
As purchased.
Last edited by Kelly Anderson on Wed Aug 26, 2015 11:40 pm, edited 1 time in total.
Re: My New Engine
Really nice work, first rate..
steamdon-jr
Boat Name: SL Phoebe Snow
Re: My New Engine
Post by steamdon-jr »
Kelly, the work you produce at Strasburg is always amazing but now I am impressed !!!
Don Fenstermacher Jr.
Re: My New Engine
Well done! The engine looks magnificent. Sorry, I have not had a look around the forum for a while so missed it.
On with the boat next?
Best wishes
Kelly Anderson
Boat Name: Vividus
Re: My New Engine
Actually yes, but I have been too busy getting her running to post about it.
She is a 23' x 6' launch built by Rappahannock Boat Works in 2005, which I purchased through Ronnie Baird in 2014. The previous owner had badly neglected the boat. The engine was seized, 7' of the keel was damaged by rot and had to be replaced, the original finish on the combing and cuddy decks was delaminated from the oak beneath it, which was black. (Note to those considering selling a worn out boat. Dim lighting and a thick coat of dirty grease in the bilge goes a long way.)
Ronnie Baird of Rappahannock graciously made time in his busy schedule to refinish the decks, while I completed the new engine, cleaned and inspected the boiler, repaired the keel (with Steve Weaver's able assistance) and replaced every system aboard, due to issues with virtually everything, including the trailer, prop shaft, and the smoke stack. Due to trim issues, I also turned the boiler to face front, and moved it aft about a foot from its original location.
I have been racing to complete installation of the engine and plumbing in time to meet with friends on Raquette Lake in New York State this last week. Didn't have time to paint the stack, or complete the hot well (which wasn't an issue due to Raquette Lake's clear and naturally tannin treated water.
You can see a short video of her in operation on Raquette Lake on YouTube.
steamdon-jr
Re: My New Launch
Kelly, fantastic work, hope to see her at Nockamixon in October.
Re: My New Launch
Looks superb! Well done; now time to enjoy.
Re: My New Launch
Kelly,
Really nice work! Love the Breisch steampump, they are fun to watch.
Dhutch
Boat Name: SNB Emily Anne
Re: My New Launch
Post by Dhutch »
Bloody hell thats a nice bit of engine, and a good looking boat to go with!
Very nice,
Mike Cole
Boat Name: Blue Buccaneer
Re: My New Launch
Post by Mike Cole »
Very nice, makes mine look rubbish
Mike Cole
