Page 2 of 2
Re: Green Twin Complete
Posted: Wed Nov 17, 2021 8:18 pm
by PatJ
My largest attempted iron pour was about 60 lbs of iron.
My largest successful iron pour was about 30 lbs of iron.
These days, I think I could relatively easily pour 90 lbs of iron using a lifting crane and a pouring cart, both of which I built.
The green twin started as a whim to learn 3D modeling, and turned into a mission to master pouring gray iron, which I finally succeeded in doing.
It was no longer about building a model engine, but rather learning how to cast engine parts in gray iron.
I have a lot of engines I would like to cast at this point.
Here is a Dake that I have 3D printed the patterns for.
Posted: Wed Nov 17, 2021 8:21 pm
by PatJ
I would really like to cast a Frisco Standard single, with a 3" bore, and am approaching completion of that design.
I plan on casting the helical gears for the valve train.
Posted: Wed Nov 17, 2021 8:23 pm
by PatJ
Here are the helical gears I will cast for the 3" bore Frisco Standard.
The are the same diameter, but give a 2:1 ratio, which is a bit of a trick.
Posted: Wed Dec 08, 2021 9:37 am
by PatJ
I got a notice today that the last part of the multi-part green twin magazine article series was on its way in the mail.
So time to open up the original green twin thread, which I had kept concealed so as to not preempt the magazine article.
I still don't have the drawings up yet, but will post those at some point on 11x17 sheets.
Pat J
Here is the introduction thread, which contains links to all of the various build threads for the green twin.
https://www.classicsteamengineering.com ... post-24343
