Steam drum
Kelly Anderson
Boat Name: Vividus
Re: Steam drum
Post by Kelly Anderson »
marinesteam wrote: Wed Jun 22, 2022 3:49 pmUsed every bit of the vertical, even with the 4" riser" for the reamer to clear the tube.
So nice to have access to the machine tools at work...
small IMG_20131117_105538_469.jpg (133.62 KiB) Viewed 52329 times
marinesteam
Boat Name: Idris
Re: Steam drum
Post by marinesteam »
Kelly Anderson wrote: Fri Jul 01, 2022 2:22 pm
Yes, it is.
Nice setup. Looks like all of the rods were used from step block set and a bit or organic material thrown in for good measure!!!!
marinesteam
Boat Name: Idris
Re: Steam drum
Added a bunch of air to two 4" tubes to make a pair of mud drums. Next comes comes some tube bending.
Re: Steam drum
Looking good Ken!
Re: Steam drum
Where are you sourcing your roller from, and how are you configuring the 90° drive for it?
marinesteam
Boat Name: Idris
Re: Steam drum
Roller is an E1 from Wicksteed in the UK https://wicksteed.com/wicksteed-product ... expanders/. Purchased extra mandrels as I expect I'll need to trim one to get it to fit into the mud drum.
Thinking of using an extended 1/4" drive, pneumatic ratchet. But that's TBD
Re: Steam drum
Hi Ken. Any progress to report? Living vicariously through your build :)
S. Weaver
Boat Name: SL Iona
Re: Steam drum
Post by S. Weaver »
Ken,
Is this one of John King's designs? They are quite elegant.
marinesteam
Boat Name: Idris
Re: Steam drum
TahoeSteam wrote: Mon Feb 13, 2023 4:18 am Hi Ken. Any progress to report? Living vicariously through your build :)
Sadly, no progress to report. Have had a few irons in the fire that had an impact on the boiler design but fell through, so hopefully back to the build once the bathroom remodel is completed.
marinesteam
Boat Name: Idris
Re: Steam drum
S. Weaver wrote: Mon Feb 20, 2023 5:20 pm Ken,
It's derivative of John King's designs, built to ASME code as far as practical (but not a code boiler due to the aforementioned tube issue)
