Rainer
Posts: 306 Joined: Sun Nov 22, 2009 5:42 pm
Boat Name: Emma and Molly
Post
by Rainer » Wed Jan 09, 2013 8:04 pm
Hello Steamboaters,
the Cylinder block is ready machined. Maybe some more honing is needed...
No design problems, no defects in the cast iron - everything is fine - I am happy with the result.
Rainer
Post
by Rainer » Thu Jan 10, 2013 9:59 am
Here is the CAD picture of the cylinder as comparison. The CAD calculates the weight of the cylinder block with 17,2 kg = 37.9 pounds.
The original part came out of the sand with 21,5 kg (47.4 pounds) and weigh 17.4 kg (38.4 pounds) after machining.
The additional weight of 0,2 kg (0.5 pounds) may result from the drafts of the mold and the rounded corners not calculated in the CAD.
Posts: 936 Joined: Sat Aug 13, 2011 6:41 pm
Post
by Mike Rometer » Thu Jan 10, 2013 11:33 am
Half a pound variation on a casting of that size and complexity, I would say is VERY close, and as it's not going to go to the moon, of no consequence at all.
Excellent!
Post
by 87gn@tahoe » Thu Jan 10, 2013 7:01 pm
Beautiful work Rainer!
S. Weaver
Posts: 356 Joined: Mon Sep 26, 2011 4:23 pm
Boat Name: SL Iona
Post
by S. Weaver » Fri Jan 11, 2013 3:47 pm
You must be pleased! Excellent.
Rainer
Post
by Rainer » Sun Jan 13, 2013 8:52 pm
Thank you all!
In the moment I am redesigning my homepage. Mostly layout and programming review...
I also started to describe my engine construction in detail - but only in German now.
Hope, to reopen my steam boat register for new entries soon...
For you here two animated gif's from my engine:
Rainer
Post
by Rainer » Sun Jan 20, 2013 2:32 pm
Can't stand it to show you this animation - even with German text...
Post
by Mike Rometer » Sun Jan 20, 2013 3:26 pm
Rainer, I think you are having as much fun doing your CAD animations as you are building the engine!
S. Weaver
Boat Name: SL Iona
Post
by S. Weaver » Mon Jan 21, 2013 12:57 am
He's running free! I hope he doesn't throw a con rod ...
Rainer
Post
by Rainer » Fri Jan 25, 2013 12:09 am
Next step. Detail from an original build in the same periode like my example:
My CAD solution:
Had to change some things at the base and at the cross-tie to avoid interferences with the oil lid.
Gute Nacht
