Page 5 of 16
Re: And Now for the Twin
Posted: Wed Feb 28, 2018 2:37 am
My vote is for M6 studs and nuts on Fred's layout above.
Dietrich, you do very nice work Einfach Klasse.
Posted: Wed Feb 28, 2018 9:40 am
fredrosse wrote:Steam engine nuts, I usually get "Heavy Hex Nuts", somewhat more meat in them. USA availability, is there a similar option in Metric?
Not that I know of Fred, but I'll check, I know what my local supplier is likely to say, "Just use a bigger size".
Doubt I'll get much if any done today, too much else going on.
Posted: Wed Feb 28, 2018 11:06 am
I spoke too soon, I managed to skip a 'task' and sneak out to the w/shop for some pics!
- Cyl Cover (12) (600 x 450).jpg (72.17 KiB) Viewed 47629 times
12 M6 in North/South formation shows that the centre four do indeed spanner-foul.
- Cyl Cover (13) (600 x 450).jpg (72.76 KiB) Viewed 47629 times
11 M6 in East/West works Ok.
- Cyl Cover (14) (600 x 450).jpg (70.51 KiB) Viewed 47629 times
Fred's 14 looks really pretty in M6.
Posted: Wed Feb 28, 2018 11:07 am
- Cyl Cover (15) (600 x 450).jpg (63.26 KiB) Viewed 47629 times
M8 in East/West works but looks a touch 'heavy'
Posted: Wed Feb 28, 2018 4:44 pm
I vote for more and smaller. Looks more like a big engine.
Posted: Fri Mar 09, 2018 6:13 pm
Hmmm! It was nice to dodge the 'domestic overload' and spend all but a whole afternoon on this problem and am rapidly coming to the conclusion that there is no 'right answer'.
After re-learning to use the DRO's P.C.D. function (and getting it wrong a few times, angles in decimals, not degs and minutes!) I tried 8 (14) and it only works (ish) if the two on the join are misplaced to be actually on the join. No biggy you might say, but that leaves the two over the valve port end, VERY close to the edge. 6 (11) works pretty much everywhere in East/West, but as we said, not in North/South. I also tried 7, but that throws up 13??? as a total, and 9 (17) with only one on the join, but that's getting precious close to spanner-foul again on the next four out, but looks nice. I haven't tried that with two (16) on the join yet; that might do the needful, but they would also need the join two misplacing slightly.
Suffice to say I now have one cyl. cover with a myriad of 'magic-marker' dots all round it.
Posted: Fri Mar 09, 2018 10:59 pm
Hi Mike,
If you provide me your bore diameters, bore center to center dimension, number of studs and desired bolt circle, I can do you a CAD drawing with X/Y dimensions. Only takes a minute.
Posted: Sat Mar 10, 2018 12:23 am
Lots of websites with calculators that will just do the math for you.
Great for checking your math...
https://littlemachineshop.com/mobile/bolt_circle.php
Posted: Sun Mar 11, 2018 4:34 pm
DetroiTug wrote:Hi Mike,
Cheers for that Ron, but I think I have that covered. The ploy was to try and use the tools available. If push REALLY came to shove, I could still resort to the old pencil and paper, how I was taught. Now I do find that quicker than CAD.
Right, first job was to set the block on the miller table, nice and true. I used the finger-clock on the bore edge, checking for the bore centre-line with the 'Y' axis, and at the same time re-proved the bore centres to be exactly 3.3".
- Cyl Cover (16) (600 x 450).jpg (73.64 KiB) Viewed 46293 times
Then having eventually re-programmed my head to the P.C.D. function, it has an inexplicable habit of converting some co-ordinates to neg. on entry, in this case the first angle. Most frustrating! I set about plotting all the possible stud number variations talked of above. In the end it boils back down to Fred's 8 (14) being the most suitable, the two on the intersection need moving about 1/16" to find the join and if I move the two at the steam port end a little, they should survive the closeness to the port. That's the only place where 7 (13) with one on the join, would be a mild improvement.
- Cyl Cover (17) (600 x 450).jpg (61.1 KiB) Viewed 46292 times
Hole positions on the cover,
- Cyl Cover (18) (600 x 450).jpg (65.16 KiB) Viewed 47457 times
and next to the bore.
W/shop time is mighty scares here ATM. Far too much Domesticity going on!
Posted: Wed Mar 14, 2018 6:22 pm
Too late!
- Cyl Covers (19) (600 x 450).jpg (74.31 KiB) Viewed 46280 times
The deed is done!
Meanwhile back at the ranch, there's been a delivery.
- Crankshaft (1) (600 x 450).jpg (64.52 KiB) Viewed 46280 times
Not only that but they've been for a spin. Just facing up for now.
- Crankshaft (4) (600 x 450).jpg (64.76 KiB) Viewed 46280 times
The next job is to source some suitable bearings. Talking about sourcing I tried for nuts and studs. Nuts, no problem, I could get the lot (valve covers as well) for just over £6, studs would be almost another £70. I think I might be doing that job I hate. One is bad enough, but thirty odd?
Photos??? I GIVE UP!!!!! The two shown below do NOT show up in 'edit' so are unremoveable.
