Bearing clearance
johnp
- Boat Name: Cardinal Queen
Bearing clearance
How do set the main and rod bearing clearances?
Re: Bearing clearance
You can use "plastigauge", sold at automotive supply houses to measure clearance. Thumbrule is 0.001 inches of clearance per inch of journal diameter.
johnp
Thanks Fred, what should I use for spacer? To open up the bearing halves.
Chris W
- Boat Name: Medea
You can get laminated brass shim stock from McMaster Carr. This allows for future bearing adjustments by peeling off a layer as needed.
http://www.mcmaster.com/#laminated-bras ... ck/=l9hvvk
