Suitable Material for Engine Exhaust Piping
JonRiley56
Post by JonRiley56 »
All,
I used regualr black iron for my exhaust last season. I am re-plumbing now so can change if it makes sense. I will be insulating so am not unduly concerned about appearance. Is galvanized a better choice ?
Re: Suitable Material for Engine Exhaust Piping
Hi Jon,
Galvanized pipe for exhaust. If you're simply ejecting over the side - yes. For condensing systems - no.
Galvanized coatings can come loose (especially if the pipe is bent) and when they do it is usually thick shards that could find their way back to the feedpump check-valves and foul them.
JonRiley56
so stick with black iron or copper ?
Jon,
Yes, that is all I would suggest using for condensing.
Also note that insulating the exhaust piping does nothing for steam plant economy, in fact it is a little detrimental to steam plant efficiency, but only slightly. Insulation for personel protection is the only technical reason that I know of with any merit.
JonRiley56
Hey Fred,
I was actually doing it just to minimize the burn possibility, trying to make it a little..more.user friendly
Jon
