Elliott Bay No.2 Running
Re: Elliott Bay No.2 Running
Good to see such very nice work, under steam. What would you say the overall cost is, in terms of purchased parts, plus how many hundreds of machine shop hours?
- Aheadslow
What can I say, beautiful engine ,once again you have made the world a little more interesting. congratulations on a job that is far more than simply well done.
regards L.E.
regards L.E.
- cowiepeters
- Boat Name: Witch of Endor
Well Done!
I thought I was nuts making one!
Peter
Peter
- marinesteam
- Boat Name: Idris
You truly are a master of your craft. Well done!
- marinesteam
- Boat Name: Idris
Would you be willing to provide any details in how the crank was prepared? (Maybe a different thread)
Especially interested in if the crank was hard chromed and how were the journals finished? If I remember correctly, the Triple's crank needed to be built up from stock as there is no casting available. If that's correct, did you finish this differently than you would have a machined from cast crank?
Thanks
Colorado, USA
Thanks
Colorado, USA
- Boat Name: grayling
Ken,
I would have a look back at old threads, as I have written my views on crankshafts in the past.
Regards Jack
Regards Jack
- marinesteam
- Boat Name: Idris
Jack,
Took a look at older posts and still have one question that wasn't covered directly,
What is your opinion regarding having the journals hard chromed, in particular in application on S.G. Iron crankshafts with Babbitted big ends. I surmise that since it wasn't mentioned you don't subscribe to this practice.
