Question about injectors
DCSmith
Post by DCSmith »
I'm considering using an injector as a secondary means of filling the boiler (I do plan on having a good hand pump as well, least anybody was worried). My local cruising waters are salt, so I will need to condense. Could I use a heat exchanger, similar to a keel condenser, to cool feedwater from the hotwell?
Hack of all trades
Re: Question about injectors
Yes, this will work just fine.
From http://valves.pentair.com/valves/Images ... jector.pdf
Maximum temperature of Suction Water:
3 ft lift and steam pressures as follows:
Standard:
120°F at 60 to 80 psi
115° at 100 psi
105°F at 120 psi
90°F at 140 psi
High pressure:
120°F at 120 PSI
115°F at 140 PSI
105°F at 170 PSI
1090°F at 200 PSI
The cooler the better from what I know of these units... Note that unless your hotwell is quite
large, the injector will soon empty it; the smallest one does 1 - 1.5 gpm. Another pump
may be a better backup for regular boiler feed.
steamdon-jr
Boat Name: SL Phoebe Snow
Post by steamdon-jr »
If you do decide to use an injector you will also want to plumb your injector overflow drain back to the hotwell as you sometimes get a fair amount out of the overflow until it settles in. do not want to put any good water into the bilge.
DCSmith
Post by DCSmith »
Thanks, everything is still in the planning stages. Are there any pumps suitable for 3 hp? I'm leaning towards a crosshead style main pump, but would like something for stationary filling, and back up.
Hack of all trades
I use a hand pump made from a piece of 1/2" brass pipe, a tee and two check valves, and a piece of 5/8" stainless polished to fit into the bore.. You can either use packing or use o-rings; both work.
For a boiler feed pump I use a hypro because it's almost dead quiet; it is chain driven from the end of the crank.
Since my fire can be turned off in a couple of seconds (steam atomizing oil fire) this seems adequate. An injector would be fun, but new ones are pretty spendy. I've used a eccentric driven pump in the past; that works but any slack anywhere soon is a knock.
