kitchen rudder
kitchen rudder
Anyone have any experience with the Kitchen rudder? I'm quite intrigued, since it lets the engine run steadily forward while the boat is made to go forward and backward and steered, all by the action of the rudder. David Gerr talks about it in his Boat Mechanical Systems Handbook (good book, btw).
From the Artemis web site:
Some videos:
https://www.youtube.com/watch?v=L-tpFo9C4zE
https://www.youtube.com/watch?v=vi0Sdkbooek
https://www.youtube.com/watch?v=GxY0yyMAhBs
Some write-ups:
http://www.scribd.com/doc/22236032/Kitc ... ull-Circle
http://www.scribd.com/doc/22985018/Kitc ... plications
This would be a big win for single handing a larger steamboat, and would make my uniflow engine a lot simpler as quick reliable forward reverse would not be required; in fact, a big single would work just fine given a reasonable flywheel.
Comments ?
=- Bart
preaton
Re: kitchen rudder
Post by preaton »
There was an article in Woodenboat magazine (Issue #185 July/Aug 2005) about making a kitchen rudder. It was on a dory with an old one lunger from memory.
Reprints would be available. There was some construction information and quite good pictures.
Be an interesting project.
Happy New Year
Paul
Re: kitchen rudder
preaton wrote:There was an article in Woodenboat magazine (Issue #185 July/Aug 2005) about making a kitchen rudder. It was on a dory with an old one lunger from memory.
Happy New Year
Paul
Thanks - I had not seen that reference. Reprints of the magazine are available electronically for $3.95 - perfect and thank you!
Reading it now.
DCSmith
Re: kitchen rudder
Post by DCSmith »
There are several threads on Canal World forums, including the narrowboat in the third video.
Hack of all trades
Mfoxchicago
Boat Name: PS Tule Princess
Re: kitchen rudder
Post by Mfoxchicago »
A very interesting concept and invention Bart. So nice of you to post. It has my "mental cogs" turning for an application those same basic ideas that might prove useable on my boat - very interesting indeed. Thanks for spurring me to "think out of the box" per say............
Happy New Year!
Mack
Capt. Mack H Fox
TULE PRINCESS STEAMBOAT CO.
Follow us as:
Facebook - @Tule Princess
Twitter - @tuleprincess
Re: kitchen rudder
One concern with that would be the lake grass we have around here on the inland waters. In the summer it can get really bad. Clearing a prop is normally just a matter of reversing the engine a few times. With all the ducting, I would think that it would be quite a problem to get it cleared out. Even a stick or fishnet etc. Also, running aground, it would be linkage and ducting versus a narrow skeg. With mine I've cut furrows in shallow water, the ducts would act like a plow.
I've never really seen any advantage to the Kitchen rudder other than it alleviates the necessity to reverse the engine rotation. Seems it would be easier to reverse the engine or make it so it can be reversed. My buddy's twin Uniflow is self starting in either direction.
Speaking of lake grass, I had a jet boat years ago, that stuff would totally clog the intake, the boat wouldn't move. It had a deflector on it for reverse, it worked OK, it wasn't like reversing the rotation of the impeller or in this case, prop. It was pretty sluggish backing up. That would be another important consideration, emergency full back maneuver to stop or reverse direction. I've been there a few times (four bells) with the Tug when some power boater or jet ski just pulled right out in to our heading. With a heavy hull it takes quite a bit to stop it.
Re: kitchen rudder
Ron,
I believe the boat Bart was looking into this setup for will be powered by a single-cylinder uniflow and steaming the San Juan Islands and further north. I think kelp would be his biggest worry, and kelp beds are pretty easy to spot from a ways away.
Re: kitchen rudder
I would build it in such a way that if needed, you could swap in a conventional rudder without some major engineering. Aside from ridiculously low efficiency in reverse and the a fore mentioned problems with fouling, it is an interesting idea.
Wes, we have eel grass up here and when Bart and I were returning from McConnell Island last Summer, we both picked up wads of the stuff. Every area seems to have its issues. Except maybe Lake Tahoe??? Pretty clear up there.
Re: kitchen rudder
Lopez Mike wrote:I would build it in such a way that if needed, you could swap in a conventional rudder without some major engineering. Aside from ridiculously low efficiency in reverse and the a fore mentioned problems with fouling, it is an interesting idea.
I wasn't aware of eel grass.
We have Eurasian milfoil (sp?) in the marinas up here. I remember my dad having to dive in to clear the prop after warming the engine every time we wanted to use his 21' boat "George H. Sandin". The 22" prop would be a basketball of weed.
On my boat I can just reach over the side and clear it quickly.
Re: kitchen rudder
There is some discussion about this contraption on an earlier thread within this forum: Ducted propellers?
A very novel and clever device, but since it hurts ahead efficiency whenever running forward, plus its tendency to catch grass and other stuff, it is better to just have forward and reverse on the engine.
