I've been restoring this Marsh simplex water pump.
a) I've made a new shaft because a previous owner banged on it and made it untrue.
b) I've made all new gaskets
c) General Cleanup
d) Paintjob
Garlock Blue Guard 3200 is the gasket material I've been using:
http://www.garlock.com/en/products/blue-gard-style-3200
The steam side is working via compressed air - the shaft is moving. Unfortunately I can't seem to get it to pump water. At best I've gotten a gurgle or a pathetic dribble.
There are some suspicions that the cylinder may not be original - leather cups were more common. I have had some ideas and after playing around on compressed air I thought I would ask.
The only remaining serious possibility I see is the moving parts of the internal checks need to lapped and/or replaced.
Any ideas?
1) First Side of Pump - note water inlet has
2) Second Side of Pump
3) Top of waterside of Pump
4) Checks - Notice some wear on tops where "cross" pattern is
5) Waterside cylinder with piston inside it
6) Waterside "Upper Decks" - Accumulator, Gaskets, Checks, Check casting
7) Waterside Cylinder lining - Note it is Full length solid, this is somewhat confusing when looking at old cutaway drawings
8) Pistons and Shaft - Large side is steam cylinder with metal compression rings. Waterside brass/bronze - 2 parts
9) Water piston and water cylinder caps/ends.
-cyberbadger
