What is this?
wsmcycle
What is this?
Post by wsmcycle »
I don't have a condenser on L'ill steamy so I previously ran my 6A on her without even the feed water pump. Now that I have determined (via the forum) that i need a mechanical feed water pump, I am going to pursue the completion of my 6A. I do not know (though i can guess) what this pump is? I don't have all of the castings for it (i bought it a few years ago on ebay) but I think it is a vacuum pump. Is that right?
I hope you guys don't tire of me. I am sincere and I will complete this 6A. I don't think i need to be concerned with this "vacuum" pump but only the feed water pump on the other end.
I had my engine in L'ill steamy a few years ago and I wrote up an unbelievable account of the disasters of the first outing. I replaced it with the original Semple engine because i felt that i didn't have enough operating pressure to fully appreciate the compound design. (how much would I need?) I have since slowed down and i am resolved to travel at whatever speed will keep the boiler >80#s. I am a speed demon. 7 is better than 6 and it's a long way from Fort Smith, AR to the Mississippi river (my goal). It is down stream however and I could make it on a raft.
LIGHT THE FIRE!!
gondolier88
Re: What is this?
Post by gondolier88 »
That would be the air pump- you correctly allude to it's use as the vacuum pump and maintains circulation in the condensing system.
I didn't see the posts regarding the water pump being necessary, but one BIG recommendation regarding the 6A boiler feedpump- try and run it at 1/3rd engine speed- so 3rpm on the engine would be one pump. The internal waterways in the design are quite restrictive and driven at cruising speed or higher almost always make a real racket as cavitation occurs and the check valves bang back onto the seats without water to stop them. A 3:1 nylon reduction gear in lieu of the eccentric makes for a far quieter and reliable pump.
wsmcycle
Re: What is this?
Post by wsmcycle »
What would this reduction gear look like? How do you replace a cam with a gear? I don't get it.
Can you reference a pic or two somewhere? Help?
LIGHT THE FIRE!!
Mike Cole
Boat Name: Blue Buccaneer
Re: What is this?
Post by Mike Cole »
I have a direct drive water/pump driven the same as this one. As the engine is a ST 5a then the revs are high. I too would like to gear down the pump as well. I suspect i will have to just throw away what i have just build a new drive. IF if ever get around to it i will post a photo or two.
Mike Cole
Re: What is this?
"What would this reduction gear look like? How do you replace a cam with a gear?"
Search on Youtube or in the forum for Jack's Elliot bay triple. Its a small square tooth gear on the crank, meshed with a large one to reduce the speed. On the larger gear is a pin with a connecting rod or linkage that drives a pump. Also have a look at the compound in Wesley's boat. Wayward belle. it uses a real nice right angle worm gear setup.
Re: What is this?
DetroiTug wrote:"What would this reduction gear look like? How do you replace a cam with a gear?"
Right.. note that if there's room on the other side of the pump, placing the larger spur gear on the opposite side of the pump, replacing the existing eccentric w/ a smaller spur gear and using a connecting rod w/ a 'dogleg' actuate the pump across the top of the crankshaft is a useful trick.
