Having bounced off the 'Search' tool and been unable to find the wealth of information I know we have on the topic of condensers and hotwells I thought I had better put up a post.
The context is that I am overhauling Frances Ann and now have the boiler and engine mounted upon a trolley. So I will soon be in a position to weigh the 'empty' boat but that will get posted as and when it happens. What I am doing is trying to optimise the pipe runs which for very valid reasons, take some odd routes. With the plant out on the trolley access is easy and smoothing things will not be difficult. It also struck me that it was time to see if I could incorporate the condenser which is installed under the hull but not plumbed.
The engine is a vee twin so I have decided to follow the lead of Lopez Mike and others who have skipped the air pump and simply let back pressure push the condensate into the hotwell. I hope to re-find the thread on hotwells, but can state that I intend to fit a filter on the outlet from the hotwell to catch the final drops of oil.
I am uncertain what sort of float valve to use on the hotwell so suggestions would be welcomed. The pipe from the exhausts to the condenser will be 22mm OD but I think the pipe to the hotwell can be done in 15 mm OD. I probably will need to make a custom fitting to ensure that the outlet pipe goes to the bottom of the condenser end casting otherwise the system will deliver no water until the whole of the condenser is full of water.
There is a sea cock which I have drawn as supplying the hand pump and the injector. Not shown is the filter which I need to fit. There is also a reserve water tank in a locker but it is not very big. It would keep things going in an emergency for a short while only hence the sea cock supply. I am not sure whether to plumb it in to the engine feed pump so that the plant could be run in puffing mode.
Things I am dithering about include whether to try to include an exhaust steam feed water heater as there are points where the two flows are almost adjacent. Should I also consider what would happen if the feed pump failed (say the belt frayed and broke)? I guess in that case one would need to switch to puffing and the injector fed from the sea cock quite fast.
Anyway, here is version 1 of the design:
(Apologies - my editing of the excess white space seems to have failed)
