But I'm the position were trying the following wouldn't be that hard. I think I can scrounge the parts from my stores of materials on hand...
Run the exhaust from one engine to another - have two propellors (possibly of different sizes) be powered by two steam engines connected in series - sort of a poor mans compound?
I have for kicks 4 years or so ago in a stationary driveway setup run one unloaded engine with it's exhaust to the inlet steam of a second engine - also unloaded. They both ran unloaded without problem (no shaft coupling between the two engines).
I understand that in a compound you want the secondary to be a larger volume. And so larger volume on if there are a third or fourth cylinders.
1) Assuming no condensor and no stack exhaust - just to ambient after the second engine would this make any difference to vessel speed?
2) Is there a concept of volume of thrust moved by the propellors being able to add or stack to a faster overall vessel speed?
3) What would the criteria of dimensions be critical to this arrangement to work positively on overall vessel speed(e.g. the relative sizes of propellors)?
4) Would perhaps the two engine in parallel be better in some way then this poor man's compound.
I realize that there a lot variables to this question. Feel free to clarify any assumptions that I haven't typed that might be important.
