A must for those whose launches puff but do not include a canopy to catch the smuts. This is a steel cylinder into which the exhaust flows through the horizontal inlet. This causes a centrifugal flow that pulls out water droplets that drain out from the drain pipe at the bottom. The dry steam exits to the funnel from the centre pipe.
Well made from 2mm steel and fitted with 1/2” BSP connections. Finished in metal primer. 18cm diameter and 23cm high excluding pipe connections.
£40 Currently located in South Cheshire in the UK 1 mile from J17 on the M6. Shipping weight is 3kg. Happy to pack for overseas shipping but will need to find the cost for you first.
Water Separator for Puffing (NOW SOLD)
