STUART Hand Force Pump 145/3 - looking for drawings
Hi,
i bought a set of castings for a manual boiler feed pump on ebay a few days ago. Unfortunately, the seller has no drawings for the pump and STUARTMODELS also has no more documents available. Peter had already helped me a little further with the results of his research, so that I was able to create the description below, but he couldn't find any drawings either.
STUART HAND FORCE PUMP 145/3
Description
No. 145/3 ..
1/2 in. Bore,
1 in. Stroke,
0.196 cu. in. displacement.
Design
Nice compact hand operated high pressure water
pumps for filling boilers. When connected via a
clack valve the boilers can be refilled whilst
under steam. They consist of a plunger operating
in a cylinder, connected to this are an input and
output pipes. Each has a one way valve
comprising a stainless steel ball bearing that sits
on a machined seating.The out stroke sucks in
water and the in stroke pushes the water out.
But because I would like to have them to create a new metric drawing set, I'm asking for help here.
In the meantime, I'm already thinking about which devices I need and how I could build them in order to be able to process the cast parts well.
Stuart Hand Force Pump.png (320.39 KiB) Viewed 80790 times
All this parts are made of gunmetal
Re: STUART Hand Force Pump 145/3 - looking for drawings
If you do not get needed information here, try the USA-based Chaski Home Shop Machinist discussion board:
http://www.chaski.org/homemachinist/
It has a large live steam discussion group and there are often plans available from those who have built such casting sets.
You will need to sign in, but will find a wealth of knowledge and information. Content is strongly monitored to keep the web board friendly.
I remain active with this group.
