It seems that my 6A has quite a lot of play in the crosshead guides. Is this normal or what should it be? I have 0.006" on the HP and 0.010" on the LP.
Gudmund
Stuart 6A
- Boat Name: grayling
Re: Stuart 6A
Gudmund,
You should be about 0.002" with this type but that's assuming things are lined up properly and the wear is even, it would probably be better to strip down and check to see if the guide faces need re-machining. The trouble with the 6A and many other brit machines is that they are too short in the conn rod length leading to high crosshead forces.
regards
regards
- artemis
- Boat Name: Pond Skimmer
Re: Stuart 6A
steamboatjack wrote:Gudmund,
regards
