Medea haul out
Chris W
- Boat Name: Medea
Medea haul out
Getting Medea underway at 0645 for her haul out and CG hull exam. Maneuvering in the basin to get lined up with the the travelift slings with a cross wind and the wheel walk of 11' of pitch on a back bell can get exciting! Shaft log for the rudder is badly wasted and will require some creative fabrication work to replace it. I really hope we don't have to pull the rudder but it will be interesting building the new one in the confines of the lazzarette.
Re: Medea haul out
Is there a place to see some pictures of this?
Chris W
- Boat Name: Medea
Re: Medea haul out
The delivery went smoothly with the crosswind being more of a tailwind and all bells answered in a timely manner. This was the first time I've gone to a shipyard and not had to wait for an hour while they splashed something else! I'll probably post some pictures as the work progresses.
Re: Medea haul out
Chris,
Any progress on pics of Media's haul out?
Keith
Master M.V. Arcturus
Atlas Imperial powered
Keith
Chris W
- Boat Name: Medea
Re: Medea haul out
Sorry about the delay for pictures but the normally hectic pace at the museum just got ramped up a few orders of magnitude and I'm spread thin enough to be transparent. That said, we splashed Medea a week ago and completed our CG inspection and drills pulling off a MOB drill in 15+ kts of wind in less than three minutes. The inspector was very impressed and let the crew know it.
All of the work had to be done through these two openings which just happen to match the width of my shoulders.
A not quite before shot of the rudder log. A repair had been made sometime ago by welding patches to the original structure. The patches were in worse condition than the original but I ended up cutting out about 90% of what was left.
Some of the larger pieces that should have been blocking the light of day in the previous picture
After
The prop was given a coat of "Propspeed" which is good for several extra turns on the top end and really cuts down on fouling. The hub was stamped "Thornycroft 6' dia 11' pitch"
Splashdown
After
Splashdown
- gondolier88
Re: Medea haul out
Hi Chris,
That's some tidy work on the rudder post there! Good to see it works well too- 3min MOB drills are hard to do, that's an impressive turning circle you must be pulling!
Interesting your boiler was made by Riley's- they were prolific marine and stationary boilermakers, and made some extremely impressive boilers, there are some great photos of there products being towed by a team of about 50 heavy horses somewhere, I can't remember where I saw them.
Keep up the good work!
Chris W
- Boat Name: Medea
Re: Medea haul out
Back to the shipyard again in the morning. The bottom paint started peeling off on our way back from the yard so they are going to haul us out again and fix the problem. The up side is that I get to take Medea out for another romp and it's not on our dime.
