Lune Valley boiler insulation question, my last ... honest!
ianrichards
Boat Name: Isambard
Post by ianrichards »
All casing panels are now insulated with ceramic board, but I seem to remember someone saying that the void space at the rear of the steam and mud tubes AND the space above the steam should be filled with a ceramic wool.
Is this advisable?
Thanks
Ian
marinesteam
Boat Name: Idris
Re: Lune Valley boiler insulation question, my last ... hone
Post by marinesteam »
Pictures? Not necessarily to answer your question, just want to pictures :-)
marinesteam wrote:Pictures? Not necessarily to answer your question, just want to pictures :-)
Hear Hear! :)
Mike Cole
Boat Name: Blue Buccaneer
Post by Mike Cole »
ianrichards wrote:All casing panels are now insulated with ceramic board, but I seem to remember someone saying that the void space at the rear of the steam and mud tubes AND the space above the steam should be filled with a ceramic wool.
Is this advisable?
Thanks
Ian
I do not know quite what you mean by the by the spaces you discribe but all of the out side walls need to be insulated. Also any space that is not a space for the flow of the flame should be filled in. In this type of boiler this means on the out side of the downcommers.
Mike Cole
ianrichards
Boat Name: Isambard
Would the downcomers be the pipes that connect the two tubes?
If so, then I understand what you mean and will fill in those spaces.
I’m pretty sure that we are talking about the same area.
Will try and post some pictures of work in progress
Thanks guys
ianrichards
Boat Name: Isambard
Dry assembly of laser cut panels
marinesteam
Boat Name: Idris
Thumbs up!
Mike Cole
Post by Mike Cole »
ianrichards wrote:Would the downcomers be the pipes that connect the two tubes?
Thanks guys
Yes all of that empty space can be filled with insultation,
Mike Cole
Looking good!
That's a very nice looking boiler indeed!
