Lune Valley boiler insulation question, my last ... honest!
ianrichards
- Boat Name: Isambard
All casing panels are now insulated with ceramic board, but I seem to remember someone saying that the void space at the rear of the steam and mud tubes AND the space above the steam should be filled with a ceramic wool.
Is this advisable?
Thanks
Ian
Is this advisable?
Thanks
Ian
- marinesteam
- Boat Name: Idris
Re: Lune Valley boiler insulation question, my last ... hone
Pictures? Not necessarily to answer your question, just want to pictures
Hear Hear!marinesteam wrote:Pictures? Not necessarily to answer your question, just want to pictures
Mike Cole
- Boat Name: Blue Buccaneer
I do not know quite what you mean by the by the spaces you discribe but all of the out side walls need to be insulated. Also any space that is not a space for the flow of the flame should be filled in. In this type of boiler this means on the out side of the downcommers.ianrichards wrote:All casing panels are now insulated with ceramic board, but I seem to remember someone saying that the void space at the rear of the steam and mud tubes AND the space above the steam should be filled with a ceramic wool.
Is this advisable?
Thanks
Ian
Mike Cole
ianrichards
Would the downcomers be the pipes that connect the two tubes?
If so, then I understand what you mean and will fill in those spaces.
I’m pretty sure that we are talking about the same area.
Will try and post some pictures of work in progress
Thanks guys
Thanks guys
- FED8A75C-83CE-4BAF-AC68-F3C4E7A1434E.jpeg (102.72 KiB) Viewed 15103 times
ianrichards
Dry assembly of laser cut panels
- 332292DB-30A6-46F8-9805-42BD268E1C20.jpeg (114.95 KiB) Viewed 15103 times
- marinesteam
- Boat Name: Idris
Thumbs up!
Mike Cole
Yes all of that empty space can be filled with insultation,ianrichards wrote:Would the downcomers be the pipes that connect the two tubes?
Thanks guys
Mike Cole
Looking good!
That's a very nice looking boiler indeed!
