Semple engines
Semple engines
Longshot request...
Wondering if someone might have drawing or would be able to get me the full dimensions of the cylinder for the 3x4" 5hp Fred Semple single (and/or the HP cylinder on the 3+5x4 v-compound, which is the same) including the valve stem to piston rod distance (or piston rod centerline to eccentric centerline).
Thank you all for your help.
Wayleon
Boat Name: S.L. Windrush
Re: Semple engines
Post by Wayleon »
I have .jpegs of the drawings of the V compound.
I will try to post the ones that may help.
Wayne Breidford
SL Windrush
Wayleon
Re: Semple engines
Post by Wayleon »
2 of 3
Wayleon
Re: Semple engines
Post by Wayleon »
3 of 3
Re: Semple engines
Thank you very much for that!
It's interesting they don't give dimensions for the overall thickness of the valve chest, valve chest face to valve stem centerline, nor the valve face to cylinder bore center. Seems a lot of "fitting" was needed in our toys because a lot of dimensions were never given...
Wayleon
Re: Semple engines
Post by Wayleon »
I'm going to post the 4th drawing and the instructions as well.
Wayleon
Re: Semple engines
Post by Wayleon »
Parts list
Semple 354DL parts 1.jpg (130.72 KiB) Viewed 12041 times
Wayleon
Re: Semple engines
Post by Wayleon »
parts list 2
Semple 354DL parts 2.jpg (121.83 KiB) Viewed 12040 times
Wayleon
Re: Semple engines
Post by Wayleon »
parts list 3
Semple 354DL parts 3.jpg (147.8 KiB) Viewed 12039 times
Wayleon
Re: Semple engines
Post by Wayleon »
Parts list 4
Semple 354DL parts 4.jpg (144.82 KiB) Viewed 12038 times
