Flying a (steaming) kite
Re: Flying a (steaming) kite
Nice one Pete, it seems my postulation in our email last night was close to the mark!
I'd suggested to Pete that there must be many boats out there with mismatched boiler/engine/prop configurations. Pure guess. :o
Some more expert data for the UK to throw into the pot.
It seems that the de-industrialisation of the UK in the '80s and '90s has essentially left a shortage of smaller businesses that weld to pressure vessel standard. The tightening of regulations and the requirement for 6 monthly re-certification and insurance has meant that it is not cost effective for those that remain to offer such a service unless they have a guaranteed flow of work. Thus to get a new firetube boiler in the UK it is likely to have to come from a big firm making a production run. There are some small specialist boiler firms but to get something may involve joining the queue. It seems, therefore that for the UK at least non-welded would be the way to go. I have some thoughts on that and will do some investigations.
The SBA design looks very nice with a water leg around the grate. I am posting it here as I thought it might be appreciated.
VFT101 p1 (438 x 600).jpg (60.33 KiB) Viewed 15061 times
Second picture to follow.
Herewith the plan drawing:
VFT101 p2 (600 x 434).jpg (70.03 KiB) Viewed 14998 times
More thoughts later.
steamboatjack
Boat Name: grayling
Post by steamboatjack »
Please note these drawings are the copyright and property of SBA Services ltd.
(Director SBA Services ltd)
Just been doing a little more playing about with the SBA Steamboat register extract. This gives us some idea of the technology adopted by boat owners in the size category about which this thread has been discussing. Interesting to see that some quite small boats have gone for compounds and that the more steam hungry twins expand as the boats get larger. Is that because there is more room for a bigger boiler?
Small Launch Machinery Bar Chart.png (11.88 KiB) Viewed 14999 times
For those who prefer the data as numbers, albeit processed here is the table:
Small Launch Machinery.jpg (30.64 KiB) Viewed 14997 times
TriangleTom
Post by TriangleTom »
PeteThePen1 wrote: Sun Jun 21, 2020 9:59 am Just been doing a little more playing about with the SBA Steamboat register extract. This gives us some idea of the technology adopted by boat owners in the size category about which this thread has been discussing. Interesting to see that some quite small boats have gone for compounds and that the more steam hungry twins expand as the boats get larger. Is that because there is more room for a bigger boiler?
What type of engines make up the "other" category? Triple expansion and turbines?
Oh My! You chaps keep me on my toes!
The 'Others' that I did not feel fitted in with the rest were:
Oscillating single
Quadruple Expansion
Single Uniflow
Horizontal Single
Going back to the topic of boilers, which was really the central aim of this thread, I am somewhat embarrassed to discover that I had overlooked the long article in Funnel (SBA club magazine) Issue 180, Spring 2019 by John King entitled "The 'Improved' Kingdon boiler re-designed for welded construction with Cu-Ni-Fe tubes. The article includes lots of original drawings for variants of the Kindon design and also John's re-design for all welded construction. I would presume that John's design has had all the appropriate calculations done and would be available. I do not know if this was simply an exercise or whether this design is available to steamboaters free or for sale. I will find out.
I think that a possible 'new entrant' boiler of simple(ish) construction that involves no welding is now available as a design for home construction.
SBA member John King has explained that his two drum boiler has been designed to make construction straight forward. For example the drums are sufficiently large to allow a Wickstead tube expander to be used with a right angle drive and power drill. The design has also been approved for expansion in the number of tubes so that the output can be matched to the chosen engine. It is also possible to mount the drum across the boat or along the length of the boat. The latter provides a better position for the water gauge although the design package includes a rather nice reflex gauge designed for a horizontal set up. The design uses Cunifer 10 for the tubes and Viton O rings for sealing. The design pressure is 250 psi.
A sketch of the boiler is given below:
John King 2 Drum Boiler (600 x 424).jpg (44.88 KiB) Viewed 14902 times
Full details are available from John King. SBA Members can look him up in the Members List while non-SBA members are welcome to send me a PM and I will pass on your request. I do not know the cost of a licence for the design.
That's a very interesting design. This coming from a VFT devotee!
One thing that would concern me would be how to make sure that the tubes were still round where they meet the drums. It's not that far from the tube/drum connection to the first bend. Maybe a temporary mandrel in the end of the tube that is removed after the bending? I am sadly ignorant of bending techniques and limitations.
