Bottle Engine 3D Model
SteamGuy
Steam on Deck
Steam on Deck
Boat Name: To be determined
Post by SteamGuy »
Here is a bottle engine that I started modeling last year.
Some of you guys have seen this already.
My intent is to use this cylinder on several different engines including a marine twin.
Pat J
SteamGuy
Steam on Deck
Steam on Deck
Re: Bottle Engine 3D Model
Post by SteamGuy »
Valve is a balanced "D".
Pat J
SteamGuy
Steam on Deck
Steam on Deck
Post by SteamGuy »
Eccentric and strap.
Pat J
SteamGuy
Steam on Deck
Steam on Deck
Post by SteamGuy »
Upper cylinder head. (Inside will have a recess at the passage entry to the cylinder, but it does not show up in the model yet).
Pat J
SteamGuy
Steam on Deck
Steam on Deck
Post by SteamGuy »
Piston.
Pat J
SteamGuy
Steam on Deck
Steam on Deck
Post by SteamGuy »
The cores will look like this (bore is 3" dia.).
Pat J
SteamGuy
Steam on Deck
Steam on Deck
Post by SteamGuy »
Cylinder patterns will be something like this.
(This is actually half of the model, and the patterns have to be made by adding core prints, closing up bolt holes, adding draft angle and machining tolerances, etc, but you get the idea).
Pat J
SteamGuy
Steam on Deck
Steam on Deck
Post by SteamGuy »
Final cylinder like this.
Pat J
SteamGuy
Steam on Deck
Steam on Deck
Post by SteamGuy »
Rod and bearing
Pat J
SteamGuy
Steam on Deck
Steam on Deck
Post by SteamGuy »
Crosshead
Pat J
