Bottle Engine 3D Model
SteamGuy
- Boat Name: To be determined
Here is a bottle engine that I started modeling last year.
Some of you guys have seen this already.
My intent is to use this cylinder on several different engines including a marine twin.
- Bottle-Assembly-03.jpg (57.17 KiB) Viewed 12269 times
- Misc-Assembly-05.jpg (73.55 KiB) Viewed 12269 times
- 2D-Assembly-01.jpg (151.93 KiB) Viewed 12269 times
Pat J
SteamGuy
Re: Bottle Engine 3D Model
Valve is a balanced "D".
- Balanced-Valve-Assembly-02.jpg (55.84 KiB) Viewed 12266 times
- Balanced-Valve-Assembly-04.jpg (49.98 KiB) Viewed 12266 times
- Balanced-Valve-02.jpg (66.59 KiB) Viewed 12266 times
Pat J
SteamGuy
Eccentric and strap.
- Strap-03.jpg (45.32 KiB) Viewed 12266 times
- Eccentric-01.jpg (59.86 KiB) Viewed 12266 times
Pat J
SteamGuy
Upper cylinder head. (Inside will have a recess at the passage entry to the cylinder, but it does not show up in the model yet).
- 3-inch-Cylinder-Head-Top-01.jpg (48.89 KiB) Viewed 12266 times
- 3-inch-Cylinder-Head-Bottom-01.jpg (53.98 KiB) Viewed 12266 times
Pat J
SteamGuy
Piston.
- 3-inch-piston-top-01.jpg (67.92 KiB) Viewed 12265 times
- 3-inch-piston-bottom-01.jpg (55.54 KiB) Viewed 12265 times
Pat J
SteamGuy
The cores will look like this (bore is 3" dia.).
- Final-Cylinder-14.jpg (102.87 KiB) Viewed 12265 times
- Final-Cylinder-13.jpg (59.29 KiB) Viewed 12265 times
- Cylinder-Cores-02.jpg (34.67 KiB) Viewed 12265 times
Pat J
SteamGuy
Cylinder patterns will be something like this.
(This is actually half of the model, and the patterns have to be made by adding core prints, closing up bolt holes, adding draft angle and machining tolerances, etc, but you get the idea).
- Cylinder-Pattern-Right-01.jpg (38.78 KiB) Viewed 12265 times
- Cylinder-Pattern-Left-01.jpg (35.58 KiB) Viewed 12265 times
Pat J
SteamGuy
Final cylinder like this.
- Final-Cylinder-09.jpg (52.46 KiB) Viewed 12265 times
- Final-Cylinder-08.jpg (48.42 KiB) Viewed 12265 times
Pat J
SteamGuy
Rod and bearing
- Crosshead-Pin-Brasses-02.jpg (36.09 KiB) Viewed 12265 times
- Rod-Brass-Top-Assembly-02.jpg (44.83 KiB) Viewed 12265 times
- Rod-Assembly-02.jpg (39.83 KiB) Viewed 12265 times
Pat J
SteamGuy
Crosshead
- Crosshead-Core-REV2-03.jpg (66 KiB) Viewed 12265 times
- Crosshead-Assembly-09.jpg (48.93 KiB) Viewed 12265 times
- Crosshead-Assembly-11.jpg (80.33 KiB) Viewed 12265 times
Pat J
