Three's a Crowd
S. Weaver
Boat Name: SL Iona
Three's a Crowd
Post by S. Weaver »
Weld-a-palooza! In addition to welding on my own boiler today (see thread and link above), Mr. Anderson and I fit up and tack out two Mike Condax-designed boilers for Mr. Anderson and Scott Lefever. A fine way to spend a Spring day! These will all be code boilers. I apologize for the quality of the photos - camera phone.
0427131021 resize.jpg (134.96 KiB) Viewed 11156 times
S. Weaver
Boat Name: SL Iona
Re: Three's a Crowd
Post by S. Weaver »
Here's some fire door detail on Mr. Anderson's boiler prior to tacking the door piece. One can see the firebox inside.
0427130846 resize.jpg (168.35 KiB) Viewed 11154 times
S. Weaver
Boat Name: SL Iona
Re: Three's a Crowd
Post by S. Weaver »
Here's the grab of mine that I posted on the blog http://steamlaunchiona.blogspot.com/
0427131447 resize.jpg (151.01 KiB) Viewed 11154 times
Steamboat Mike
Steam on Deck
Steam on Deck
Boat Name: Catawissa
Re: Three's a Crowd
Post by Steamboat Mike »
WOW! Beoooootiful job, post more pics please. Best regards, (Steamboat) Mike
S. Weaver
Boat Name: SL Iona
Re: Three's a Crowd
Post by S. Weaver »
Compelling design, Mike. It's a joy to weld.
Steamboat Mike
Steam on Deck
Steam on Deck
Re: Three's a Crowd
Thanks Steve, kind words. There is something primal about welding. No shots of the tube sheets, what size tubes, how many? Steamboat Mike
Re: Three's a Crowd
Steamboat Mike wrote: There is something primal about welding.
I'm sure it's the 'watching fire' thing. :lol: :lol:
S. Weaver
Boat Name: SL Iona
Re: Three's a Crowd
Post by S. Weaver »
Steamboat Mike wrote:Thanks Steve, kind words. There is something primal about welding. No shots of the tube sheets, what size tubes, how many?
Mike, your design has 90, one-inch tubes. I forget the length - but they would be the same length as yours.
The scotch has 50, 1.5" tubes, 24" long.
Re: Three's a Crowd
Welding, welding, welding, that seems to be the thing this spring in PA. Is that welding table in your pictures made from a piece of plate?? Bet that is not too easy to move around, unless you have an overhead gantry crane.
S. Weaver
Boat Name: SL Iona
Re: Three's a Crowd
Post by S. Weaver »
fredrosse wrote:Welding, welding, welding, that seems to be the thing this spring in PA. Is that welding table in your pictures made from a piece of plate?? Bet that is not too easy to move around, unless you have an overhead gantry crane.
Yeah, Fred, it's no Acorn. The ten-ton overheads shift it around for us ...
