Ash pan
johnp
Boat Name: Cardinal Queen
Ash pan
Post by johnp »
How thick should my ash pan be under the grate in my WT boiler? 1/8"? 3/16"? 1/4"?
Re: Ash pan
I would suggest it depends entirely on the size, shape and configuration, but if designed well, 16G (1.6mm) should be more than adequate.
Dhutch
Boat Name: SNB Emily Anne
Re: Ash pan
Post by Dhutch »
Wet or dry ash pan? Stainless steel?
Ours is a dry ashpan, mild steel, around 5mm thick, but it also holds the weight of the point which is a fairly large firetube boiler!
