Recent Pictures
Cloth Rolled on Bottom.jpg (65.59 KiB) Viewed 25746 times
Wetting out bottom
Wet Out Bottom 9oz Glass.jpg (80.55 KiB) Viewed 25746 times
Added 10oz cloth over the 9oz on the transom only.
The next step, after some preparation sanding, is to apply the 10 oz cloth and wet out the sides, then fill the weave on the sides.
Three options here:
1. Cut the hull off the building board and turn it 90 degrees to do wet out and fill coats on each side panel.
2. Apply the cloth and wet out in the bottom up orientation, then Cut the hull off the building board and turn it 90 degrees to do fill coats
3. Do wet out and fill coats on each side panel in the bottom up orientation
Transom 10oz over 9oz.jpg (68.75 KiB) Viewed 25746 times
mcandrew1894
Post by mcandrew1894 »
Hi Fred,
I glassed the sides while on the strong back. It went fine.
Getting a couple of friends to help is worth the effort to get the pizza and beer. :D
Early Sept Progress, 10 oz cloth onto sides
Wet Out Sides.jpg (81.18 KiB) Viewed 25716 times
10oz Side Cloth.jpg (61.48 KiB) Viewed 25716 times
Sawing the Boat from the Building Board
A few leftover screws.jpg (78.77 KiB) Viewed 25716 times
Saw from Building Board.jpg (73.82 KiB) Viewed 25716 times
The fill coat of epoxy on the sides. We decided to turn the hull so the fill coat would be placed on horizontal surface. This minimizes to runs of epoxy, which tends toward drips and runs much more than ordinary paint.
Positioned for Sides Fill Coat JP.jpg (91.98 KiB) Viewed 25716 times
Starboard Fill Coat 01.jpg (88.23 KiB) Viewed 25716 times
Hull exterior finally glassed and fully coated with epoxy. Keel was added (1.5 in x 3.5 in fiberglassed wood). Turned the hull over on the 19th of September, and racing to get going under steam on the last steamboat meet of the year (near me) on 10 October.
Finally Upright.jpg (44.99 KiB) Viewed 25686 times
mcandrew1894
Hi Fred,
Great Progress!....I'm a routing for ya!
but...don't cut corners in the name of speed...take enough time to forfill your desires for the final outcome.....
Best of luck to ya bud!
Stirring the Pot
Stirring the Pot
Boat Name: Steam Queen
Post by farmerden »
Hey Fred Don't worry about the destination-What an incredable journey! Thanks for sharing. Den
