Recent Pictures
- Cloth Rolled on Bottom.jpg (65.59 KiB) Viewed 25743 times
Wetting out bottom
- Wet Out Bottom 9oz Glass.jpg (80.55 KiB) Viewed 25743 times
Added 10oz cloth over the 9oz on the transom only.
The next step, after some preparation sanding, is to apply the 10 oz cloth and wet out the sides, then fill the weave on the sides.
Three options here:
1. Cut the hull off the building board and turn it 90 degrees to do wet out and fill coats on each side panel.
2. Apply the cloth and wet out in the bottom up orientation, then Cut the hull off the building board and turn it 90 degrees to do fill coats
3. Do wet out and fill coats on each side panel in the bottom up orientation
Three options here:
- Transom 10oz over 9oz.jpg (68.75 KiB) Viewed 25743 times
mcandrew1894
Hi Fred,
I glassed the sides while on the strong back. It went fine.
Getting a couple of friends to help is worth the effort to get the pizza and beer.
Early Sept Progress, 10 oz cloth onto sides
- Wet Out Sides.jpg (81.18 KiB) Viewed 25713 times
- 10oz Side Cloth.jpg (61.48 KiB) Viewed 25713 times
Sawing the Boat from the Building Board
- A few leftover screws.jpg (78.77 KiB) Viewed 25713 times
- Saw from Building Board.jpg (73.82 KiB) Viewed 25713 times
- Liftoff.jpg (83.51 KiB) Viewed 25713 times
The fill coat of epoxy on the sides. We decided to turn the hull so the fill coat would be placed on horizontal surface. This minimizes to runs of epoxy, which tends toward drips and runs much more than ordinary paint.
- Positioned for Sides Fill Coat JP.jpg (91.98 KiB) Viewed 25713 times
- Starboard Fill Coat 01.jpg (88.23 KiB) Viewed 25713 times
Hull exterior finally glassed and fully coated with epoxy. Keel was added (1.5 in x 3.5 in fiberglassed wood). Turned the hull over on the 19th of September, and racing to get going under steam on the last steamboat meet of the year (near me) on 10 October.
- Finally Upright.jpg (44.99 KiB) Viewed 25683 times
mcandrew1894
Hi Fred,
Great Progress!....I'm a routing for ya!
but...don't cut corners in the name of speed...take enough time to forfill your desires for the final outcome.....
Best of luck to ya bud!
- Stirring the Pot
- Boat Name: Steam Queen
Hey Fred Don't worry about the destination-What an incredable journey! Thanks for sharing. Den
